Will these rims fit my '96 W202?
AK84
Hi guys,
I need some help. I'm putting new rims on my W202 because the old ones are for ML and don't fit well (I think their offset is 62).
So I found these new rims. the guy sells them with tires too. These are the data for the tires and rims:
Tires: 225 mm, Radial
Rims: 17", 7,5", ET 37 mm
So the question is will these fit without a problem???
The size of thos wheels in the picture are perfect in size, the only thing to check is the size of the bolt hole, your car uses 12mm diameter bolts, just check that the ones in the picture are not 14mm
You can buy cone adapters but not that cheap
A
AK84
Thx television!
Edit: One quick question: Is the bolt size information visible somewhere on the rims?
Thx television!
No it is not, I tried to see but I could not be accurate enough, what car did they come off
A
AK84
I recall the guy sad they were on a CLK 320. Could be wrong though :S
Well a 208 uses 12mm bolts so you should be OK
A
AK84
I also found this picture with same rims on a C class coupe:
So I should be OK?
So I should be OK?
Thats a 203 and I believe 14mm,,send a PM to S-A-M,, he has a 203 and should know
I think that you should phone Chris Murray from that link and ask him about the 14 mm holes, he is a nice helpful guy and also has the adapter cones if they are 14mm
A
AK84
Thx television, but I live in Hungary and it would cost me more to phone to the UK :p Anyway I sent a PM to S-A-M. Thanks for helping mate! :)
