will they fit?
RPSXR
hi guys
question: will wheels with these specs fit my car? 8J X 17"
ET 30 IS THE OFFSET
:confused:
thx
rgds RP
R
RPSXR
jeez blobcat, you're everywhere eh? and an answer for everythin. perfect thanx for that.
where i looked was for brabus wheels, but in this size they've left out the et-value?!
any ideas? thx
rgds RP
I think the off set maybe too small, however I'm sure a few other members will pop up with the definitive answer.
R
RPSXR
if the offset is too small, can you fix that with spacers? or am i now on the wrong track?
You could go along that route, just be very careful as MB wheels are Hubcentric, i.e. they centre on the Hub, not with the bolts. So any spacer (or replacement wheel) has to be Hubcentric as well otherwise you will have bad vibration.
R
RPSXR
ok. but would a brabus wheel not be hubcentric too then since they're made for mercs?
If the Brabus wheel is specified for MB then they will fit correctly.
malcolm
rajinder_1
Midlands
Guys i think that this explains the vibrations in my c class. I have got 5 mm spacers on the rear wheels and find that this is very shakey on the motorway.
What is hubcentric and where can i get the hubcentric spacers from?
Regards
Raj
clive williams
RPSXR said:
hi guys
ET 30 IS THE OFFSET
:confused:
thx
rgds RP
I doubt that these will fit without the use of spacers as the straight conversion for the 8J will require an ET35. In my experience, having fitted 8Js to our S210 avantgarde there is precious little space left to clear the suspension with the standard offset that equates to the ET35 on the 8J. If you want to fit yours with spacers then obviously you need 5mm (or 6mm) spacers. Don't forget that you will need the correct length bolts as well as the standard ones will be too short. I'm not sure if the bolts come in a convenient 5/6mm extra length and you may have you buy longer still bolts and cut them down.
Clive
500E
E320CDIT210
R
RPSXR
thx guys; let you know what happened in due time (cause i'm picking them up in a week and-a-half) and post some piccies. as there should be more on here anyway!!
rgds RP
rgds RP
If your after more options to fit, what have you installed already? I'm sure forum members would give lots of advice - England flag perhaps :confused: :rolleyes: :cool:
R
RPSXR
So they DO fit
Here's finally the result. And thanks for all the advise, but in the end it was just a straight bolt on and not as difficult as some expected!!!!:rolleyes:
rgds RP
www.ckinsurance.co.uk
