window electrics after glass replaced
alan w
E300TD S plate 1998. Autoglass replaced the passenger front window and the window will not stay up unless I hold down the switch as the window reaches the top. The autoglass guy said there is some reset for this and that I should contact merc dealer.
I have tried holding the switch down for 30 secs as someone advised but this has not worked.
thanks
alan
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
The reset procedure should need to be done everytime the cars battery is disconnected or the power to the windows or sunroof has been unlpugged.
Cycle the window to the fully down position and fully press and hold switch for approx. 10 seconds, then repeat the procedure with the window fully up. Do this as nessacary to all windows and roof.
Hope this helps.
With Andy's post above, the key has to be turned to 2
A
alan w
great info thanks ever so much I will try when home this weekend.
