windows and sunroof
handyman
belfast
2003 w211 e270cdi elegance
hi i have a1995 c200 w202 the windows and sunroof are not working with the ignition switched on, they will work with the drivers door open, i have checked the fuses in the boot and they are a- ok, there is a green relay on the same board with a 30amp fuse attached which is also ok i don't know what this relay does.
any help please
handyman
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
The green relay is for your fuel pump; have you done a "search" for your problem as I think this came up recently but I can't remember if there was a solution posted.
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
The windows still working with the drivers door open is normal it may do it on the passenger side too its a courtesy thing and is standard on all 202s with elec. windows, and indeed most Mercs.
I remember on my old BMW it had a trip switch which when tripped it would cut the power to the windows if the they got jammed or were stopped when closing.
Wonder if a 202 has one? i would of thought so, not sure where though.:confused:
H
handyman
belfast
thanks c220gjs done a search as you said, a couple of threads but no solution.
i have checked every fuse front and rear and they are all a-ok
