Windscreen Washer Issue
lockt
2016 A Class A180D
The car (2016 A Class A180D) hasn't been getting much use lately - so this could have been an issue for god knows how long, however I noticed when using the windscreen washers only the passenger side is getting sprayed (and it's more like a dribble) and no water sprays onto the driver side.
I lifted up the bonnet and it seems the screenwash is just leaking out of the end (circled), is it missing a cap or something?
If so, where exactly could I find one? I've had a quick google but I can't seem to find anything that looks applicable.
Any help would be appreciated.
Thank you!
M80
Derbyshire
Not so easy to see from the photo,
but that's a hose connector.
Is it possible you've lost the hose link from wiper to it?
L
lockt
2016 A Class A180D
I'm not sure. It was recently serviced so it could have came off during that I guess.
It looks to me like it's just open ended and it's missing a cap of sorts, but I haven't the first clue what to look for. I've had a look around to see if there are any loose parts but I can't see anything.
Chrishazle
Nr Ashford, Kent
If what we're seeing in the green circle is the drivers side jet as well as the open hose connector, it could be that like my S204 there should be a short piece of pipe with a cap in the end that fits onto that open hose connector. That provides a useful place for backflushing the pipework with water or air if you get blockage in the system.
L
lockt
2016 A Class A180D
Yeah, that's exactly it by the sounds of it. I just need to figure out where I can purchase that piece for the end, I can't find it anywhere.
EmilysDad
Bury Lancs
ML350
find a piece of tube the right dia .... shove it over the fitting & then find something to blank the tube off - small bolt or squash the end over :)
Chrishazle
Nr Ashford, Kent
@lockt I may have the appropriate bit in my garage, but the problem will be, if I find it, you do not have enough posts for PM's (conversations) so don't know how we could communicate! Let me look in my garage and revert on here.
Chrishazle
Nr Ashford, Kent
I think this may be what you need, if so pop your email address on here, once I've seen it and contacted you I'll tag a mod to remove it.
mioba
Nottingham and Köln
I bit of pipe with a blanking screw in it will do the job if you can live with that.
Otherwise take a trip to the dealers and ask them to pull pull up the IPL for correct part.
To figure out if its just a blanking hose, put a blob of blu tak in there, bonnet down (otherwise they wont work) and operate the washers.
Chrishazle
Nr Ashford, Kent
Can't be too important, no reply yet from OP to what I found in my garage!
L
lockt
2016 A Class A180D
Ah that'd be amazing! You can contact me at xxxxxx - thank you so much
Chrishazle
Nr Ashford, Kent
Have emailed you for your postal address. @Blobcat, can you please remove his email address from the post above, many thanks.
Chrishazle
Nr Ashford, Kent
Many thanks Russ, appreciate your help, Chris
josie15
a180 d year 2017
I need the same part could you find me one?
josie15
a180 d year 2017
Could you find me the exact part as per your post
