Wow ok never knew these existed, we live and learn, thanks for thatI've never needed or used one but I believe this is what you need.
Windscreen Washer Nozzle Adjustment Key for Mercedes Casement Cleaning System | eBay
The real color of the item may be slightly different from the pictures shown on website caused by many factors such as brightness of your monitor and light brightness.www.ebay.co.uk
Pins worked well with the older water nozzles. The last time I adjusted my nozzles I used a thick darning needle, a pin is a bit narrow on the new style nozzles.Depends upon the type, but a pin normally works (if it's the small circular hole type)
thanks will give it a go, its not much of a adjustment but they only hit the bottom 6" of the screen.Pins worked well with the older water nozzles. The last time I adjusted my nozzles I used a thick darning needle, a pin is a bit narrow on the new style nozzles.
