wiper fuse blowing!!
sara786
HI EVERYONE,
I HOPE SOMEONE CAN HELP ....MERC CI80 P 1997
MY WINDSCREEN WIPER HAS STOPPED WORKING ALTOGETHER,I THOUGHT A FUSE HAD BLOWN BUT WHEN I REPLACED IT ,IT BLEW AS SOON AS I SWITCHED ON THE WIPERS. THE BACK HEATER HAS ALSO STOPPED WORKING AND THE BEAM LIGHT WONT FLASH. I'VE GONE THRU A DOZEN FUSES BUT AS SOON AS I REPLACE IT IT BLOWS...ANY HELP WILL BE MUCH APPRECIATED
I JUST HOPE IT DOESNT RAIN IN THE MORNING!!
SARA:cry:
Dec
Ireland.
W202
Dose the fuse blow if you turn the wipers on BY PRESSING THE STALK INWARDS ONLY so as to get 3 sweeps of the blade? (plus a little squirt of the jets) DO NOT turn on the intermittent, slow or fast setting.
Dec
Suki
Berkshire
W251, S211 320 cdi Avantgarde (2005), W202 250 td (now sold), W245 with lots of extras
hi, this sounds like the wiper motor is drawing too much current.
Chances are that you need to service/replace the wiper motor.
Aviator
1992 190E 2L AUTO
You need to disconnect the wiring at the wiper motor ,replace the fuse and sw. on wiper if the fuse stays intact looks like your wiper motor is bad
MarkCL
Hampshire
W211 E320 CDi Avantgarde
If it only happens when you try to turn on your wiper then I suggest you check the mechanism to make sure it hasn't seized. There are a number of posts detailing how to lubricate the single wiper mechanism and to be honest you'll at least have a better idea of what may be wrong once you've taken the covers off and can see whether there's any physical damage anyway. Hope thats helps.
Cheers,
Mark
sara786
hi,
thanks for your reply ,but can you let me know where the wiring for the wiper motor is located,so that i can disconnect and check the fuse.
Your prompt reply would be much appreciated.
sara
hmang
disconnect the wire that comes out of the motor
Dec
Ireland.
W202
Remove the front fuse box lid.
There are about 4 ? screws to remove, this will give you access to the windscreen end of the fuse box.
There is a plug there, I think it is the only one, there should be 5 ? wires coming from it.
Now, on my car, C180 1994 it is not at the fuse box but beside the wiper motor, which means removing the trim at the bottom of windscreen, however I think yours is under the fuse box , which is much easier to get at.
Dec
sara786
How to open up windscreen wiper gearbox
hI,
DOES ANYBODY KNOW HOW TO TAKE THE COVER OFF THE WINDSCREEN WIPER,AS IVE NEVER DONE THIS BEFORE STEP BY STEP DIRECTIONS WOULD BE MUCH APPRECIATED,i VE SCANNED THE FORUM BUT THE LINKS ALL SEEM TO BE BROKEN....
QUICK RESPONSE NEEDED
SARA
sara786
The Fuse Still Blows
hI,
THANKS FOR THE LINK, I,VE TRIED BY DISCONNECTING THE MOTOR AND EVERYTHING WORKS..DEMISTER,FLASH, ETC BUT ASA YOU TURN THE LEVER FOR THE WIPERS THE FUSE BLOWS CAN THIS BE SAVED OR IS IT TIME FOR A NEW MOTOR FROM MB AKA (MEGA BUCKS!!!!!!)
SARA
Dec
Ireland.
W202
Its still blowing fuses when wipers switched on, so that leaves the motor or the stalk.
I haven’t done this but the TOP INCH of the stalk can be pulled off so as to clean/inspect the switch inside. There is a spring inside which can shoot out so I would advise that you put some kind of transparent plastic bag over the stalk so as to catch the spring, and anything else, when it pops out. Sorry I don’t know any more about the stalk, maybe someone else may know more.
If that doesn’t work then it may be the motor.
Dec
hmang
it cant be the motor if the fuse blows while the motor is disconnected.
Dec
Ireland.
W202
hI,
SARA
Your right hmang, the way I read SARA’s post #11 is that when the motor was disconnected, the flasher, etc work fine, I wrongly assumed that SARA then reconnected the motor and then turned the lever for the wiper, which blew the fuse, but SARA didn’t actually say that the motor was reconnected, so as you say that would exclude the motor from the inquiries.
So that leaves some other fault, wires/fuse/fuse box wet? or stalk.
Dec
www.W140.co.uk&www.r129.co
