wiper problem in SL 320 1999
hemalparikh
I have 1999 SL320 which i realy enjoy.
For last few months, on and off problem with wiper system specially when it is raining!
it will not work and at the same time, the indicator goes funny and only shows left signal. yesterday, the electric mirrors which were folded when parked, i could not reopen them fully. also music system aslo stops working when this happnes. It is intermittent problem.
Please advise.
I would suggest that you pull out the multi function N10 relay and spray some none drying switch cleaner on all the pins. If this does not solve it the other known problem on a 1999 129 is the ignition switch failing
You could check this by turning on the radio,, if it crackles or goes off when the wipers are on then possibly more the switch
It could be a dry joint inside the N10 relay
H
hemalparikh
Thank for suggestion. I do not know how to pull out N10 relay so i will take to garage. To inquire for parts, should i ask ignitian switch for 1999 SL? any idea how much it can be?
H
hemalparikh
Thank for suggestion. I do not know how to pull out N10 relay so i will take to garage. To inquire for parts, should i ask ignition switch for 1999 SL? any idea how much it can be?
It has to be worked out if relay or switch, a competent man should know where to check for the missing voltage when things stop.
We had one a while back where the N10 had been getting so hot the sockets in the fusebox were melted.
In about 1997 the wiring was changed passing more current through the switch, rather than the fusebox
H
hemalparikh
Thank you. I will take to garage tomorrow
