Wiper rest postion Problem C200
Stables
c200 1996 2L
Hi I have a problem that when I switch my wiper off it comes to rest in the middle of the screen and not in its normal rest position. Its a 1996 c200......It did start to stick but cleared itself and started running smoothly but when I came to turn the wiper off it stopped upright. Can anybody help
Cheers
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
panason1c
Somerset, UK
Cheers
Wiper motor spindle nut come loose....remove the scuttle paneling...position the wiper in the 'park' position, re-tighten the spindle nut.....job done....easy diy.
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
this job is really easy to do once you know that the turtle shell is held in place with two tabs situated more or less in the bottom 1/3 of it, however the tricky bit is prizing the turtle shell plastic up and to do that I used a small piece of metal with a fingernail sized tab on the end of it (at 90degrees to the metal rod) to slip under the plastic and release the tab. once done access to the two rails was straightforward enough and i liberally greased them
did the job today on my c220 (1995) even though there was no problem, i guess after reading these threads i decided it was time to take some preventative measures, and i must stress again
the job was EASY
cheers
anyweb
Stables
c200 1996 2L
Thanks to everybody for taking the time to respond.....I will let you know how I get on
Cheers
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
If it parks directly up (vertical) everytime in 'exactly' the same place it could be someone has modified to do this on purpose as its a customising thing.
