wipers non parking
steven edwards
New Registration
HI all , can anyone help , got 1983 280ce 123 mdl with wiper problem , in that turn to park position and stops where wipers are at that time not in the park position . Can it be the wiper relay ? , if so where is it situated ,
190
Banned
Scotland
Sounds like either a bad earth or the wiper motor itself would check the wires at the motor.
stwat
Sheffield
1989 300SE
I had this once on a ford fester. When i investigated i found a wire had come loose on the motor. I clipped it back on and all was well again. (well, apart from the fact that i was still driving a ****** ford fester!!!!)
Stu
N
nasher
If they stop in the same (wrong) position all the time, it may be that the mechanism needs adjusting. Inside the car where the Mech joins to the motor, there's a nut. Turn the wipers off as normal, then loosen the nut an push the wipers in the park position, then tighten the nut again.
This is what happened to my fintail, no reason to think that this wouldn't work on an old 123
www.ckinsurance.co.uk
