wires came off the Ignition switch -
Status
Not open for further replies.
mattgm
OK - while removing (the cave man method ) My ignition lock assembly on my 300e 4matic . The wires all came off the back of the switch - each of the posts are labled and all of the wired are color coded - . I have the MB service cd on order - does anyone know or have the right wire >plug ?? basicaly what wire goes where ?? help
Barnie
Scottish Borders
ignition switch
Hi Mattgm
I once replaced my ignition switch so I appreciate your problems
Do you have 5 or 3 wires to connect ?
Does the terminals on switch back have numbers adjacent ?
If three then connect as follows
RED to terminals 30 & 30
RED & PINK to terminals 15
If five, then connect
PINK & YELLOW to 15R
GREEN & WHITE to P
Hope this is of some help,
Regards, Barnie
M
mattgm
WHAT WIRE GOES WHERE -
THANKS -- HERES WHAT I HAVE -
PINK (OR RED )
pINK (OR RED )
gREEN WITH WHITE TRACE
wHITE WITH GREEN TRACE
WHITE WITH YELLOW TRACE
pURPLE TWO WIRES ONE PLUG
WHITE WITH RED TRACE
THE WHITE COULD BE CALLED PINK FOR SURE -
TERMINALS CLOCKWISE - p30 ,15 ,30 ,15X,30 ,50,15R
M
mattgm
THANKS -- HERES WHAT I HAVE - JUST NEED TO FIGURE OUT THE LAST TWO 15 X AND p 30 :shock: :?:
PINK (OR RED ) >>30
pINK (OR RED ) >>30
gREEN WITH WHITE TRACE >>> ??
pINK WITH GREEN TRACE >>> ??
PINKWITH YELLOW TRACE >> 15r
pURPLE TWO WIRES ONE PLUG>> 50
PINK WITH RED TRACE >>15
Barnie
Scottish Borders
IGN\SWITCH
the wiring diagram I am using is from the Haynes manual ,so therefore may not be quite right for your model ,but will be similar.
according to my diagram 15x has no connection, & p30 is listed as P with a green/white cable attached
there is no purple cables at all listed in the diagram but there are VIOLET
THE violet cables are connected to the starter motor VIA a reverse switch connector box/junction & are connected to terminal 50 AT THE IGNITION SWITCH
sORRY i CAN'T be more precise,the BEST OF LUCK
regards , Barnie
Status
