Wiring for a multi-disc changer
bigjobby01
I have a '97 C200 Elegance, I am thinking of fitting a cd multi changer in the boot. There is a blaupunkt radio cassette fitted, not sure if this is the original factory fitted unit. Is there anything pre wired for a changer in the boot? Or if I want one do I have to wire it completely?
Many thanks
Pls check your car against the attached web site;
http://www.detali.ru/cat/oem_mb0.asp?TP=1
Then select Electrical Equipment (82) then Cable Harness for Radio (320) and you can see the cables. No. 53 is for the CD changer.
If yours is a C200 020 then below is the correct page
http://www.detali.ru/cat/oem_mb2.asp?TP=1&F=202020&M=111%2E941++++++111%2E945&GA=722%2E422722%2E602&GM=717%2E417717%2E418&CT=F&cat=44V&SID=82&SGR=320&SGN=14#065
Pls note the details at the bottom of the page which list out which models and dates the options are fitted to.
bigjobby01
bigjobby01
Thanks for the help, much appreciated
