Please excuse my mechanical ignorance!
My E240 (1999 - 80k miles) has just flown through its MOT, however, the tester pointed out that the crank pulley (if that is the correct term for the black pulley with numbers marked on it) is worn and will need replacing.
On further inspection it appears that a black rubber seal from within the pulley is working its way loose causing it to spin slightly uneavenly.
Is it possible to 'fix' this and replace the seal or will I need to replace the entire pulley. I have been quoted £400 for the pulley plus £200 labour as it involves removing the radiator.
Finally - I do not cover huge miles in the car as I have a company car for day to day use - if I wait for it to fail - whilst I know it will immobilise the car - will it cause additional damage to any other part of the engine?
Thank for looking, hope you can help.
