Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
I am worried the 4 bolts holding the antiroll bar bush might have corroded, and be difficult to remove.
On 2 of the bolts, I can get to the exposed end of the bolt, and hence have sprayed penetrating oil on them for a few days. The other 2 go into a box section. So I can’t spray the end of the bolt, only the head
If any of the threads attached to the subframe sheared it would be a nightmare … very limited access.
Q: Is it better to use my 3/8” drive (air driven) impact gun, starting slowly at low pressure/torque. Or a spanner? Which is gentler? i.e. less likely to shear off.
A Class is 2002 so 22 years old, on 72,000 miles.
reason for concern:
All the bolts on the suspension parts came undone nicely except one.
The bolt securing the Top Suspension mount-bearing block to the body sheared off see photo
It seemed tight on a 3/8” rachet so I used my long wheel brace circa 900m bar. It seemed to move then sheared off.
Luckily the mounting block was to be replaced as the bearing was knackered.
kinda shocked the steel bolt sheared going into aluminium? I thought the aluminium thread would have given first.
reason for concern:
