Devon
- Oct 20, 2009
- Location
- Mid Devon
- W210 E200K Estate + BMW 320 Gran Turismo
Car is a 2001 210 Estate E200k.
A week or so ago I started the car and selected reverse - nothing happened. Waggled the stick back and forth a bit and then it engaged with a jolt. Reversed out, put it into drive and set off, only to find that it would not change up (I think) beyond second ratio. Eventually stopped the car, switched off then restarted. Gearbox worked fine. However I have noticed that now, when selecting drive or reverse from park, it engages with a bit of a jolt and the changes thereafter are not so smooth. In the past it always engaged with hardly a murmur and changes up and down were always silky smooth. Is this signalling that a serious problem is developing? By the way the car has done 80,000 miles and the ATF has never been changed. Also, probably a coincidence, but just before this problem occured I had switched the gearbox to W for a few days, just to try it out and then switched back to S.
Any advice gratefully received.
Mike
Mike
