tony jr
I am having problems with my GL320. The engine will turn over easy and start. It will run fine for about 30 seconds then cut out. Any ideas what the problem could be? I have a Creader VIII and the only code I picked up was P0340 camshaft position sensor. I cleared the code started the engine and it stopped the same but no fault codes logged suggesting that that was an old code. The only other background is that I have just changed the air suspension pump due to the old one failing and blowing the fuse
