renrutp76
- Mar 27, 2012
- Location
- Chester
- X218/2014/CLS250CDI_W211/2005/E500 Avantgarde
Thanks for taking the time to read this....
I recently had my front wheel bearings replaced, with Febi units. When I collected the car, the guy said that one of the ABS pickups must have been faulty as the car was displaying several different faults (ABS/ESP/ Tyre warning unavailable). I have had the codes read as follows: -
442800 Left Front Axle RPM sensor has a mechanical fault current & stored
446800 Right Front Axle RPM sensor has a mechanical fault current & stored
457500 At least one of the RPM sensors is delivering an incorrect rotation direction.
The faults were cleared, and the live values were observed on a test drive, all 4 wheel speeds were consistent with each other within 1-2 miles per hour.
However the fault will not clear even with a Star diagnostic.... any ideas...?
