Xenon led kit
Ben2057
North Wales
Cls320 Cdi W219 2006
Hi all, just bought some rear license number plate xenon led kit, is there a easy way to fit these, is easier to remove the trim inside the boot lid or do I have to take the chrome trim off to gain access to them, they come as a complete unit not just the bulbs, o and it on a 2006 cls320cdi
V6Matty
Newark, Nottinghamshire
could you post a picture of what you have bought or the url of some information about them, will help work out how it could be done.
B
Ben2057
North Wales
Some photos of the lights
Mercedes
[/URL][/IMG]
B
Ben2057
North Wales
Anyone got and ideas yet please
Corned
East Midlands
2005 S211 E320CDI Avantgarde
You would normally just carefully pry them out of their location with a small flat-bladed screwdriver, making sure you don't scratch the surroundings. Then pull the unit clear and disconnect the wiring. You can see the locating lugs - 2 each side - in the photos. The flat blade might need to press them in a little to release the unit.
Refitting is the reversal to removal.
I am however more curious about the replacement lamp units. Are they xenon or LED - they can hardly be both!
drmw
Yorkshire
www.autonomed.co.uk
That was my initial thought too - a couple of headlight power bulbs seemed a tad extreme for number plate illumination!
However, that is what a lot of LEDs are called by sellers - see http://www.ebay.co.uk/bhp/501-led-xenon-bulbs as an example.
LED is the answer
V6Matty
1+ for Corned's answer, should just pop out but will need a little patients i expect.
whitenemesis
CLS55 AMG '05
Removal of the licence plate lamps is from inside the boot. You will need to remove the boot lid panelling to release the retaining clips.
whitenemesis
CLS55 AMG '05
Curious, I just checked my owner's handbook and it states to replace the bulbs one removes the two screws, removes the lamp unit, replace the bulb and refit the lamp unit....
Suggest removing the two screws and see what falls out!!
That is what WIS says Peter, very unusual if there are screws, then screws it is, but I cannot see any holes
whitenemesis
CLS55 AMG '05
Well, Ive just looked at mine and there are two screws per light. My feeling is that these simply hold on the glass lens. The light unit is held from inside the boot, as WIS states..
That would make more sense so job done :D
B
Ben2057
North Wales
The two screws only hold the cover in place, simply unscrew and remove to change bulb only, to remove the whole light assembly you have to take the trim off the boot door to gain access, then in your car has the chrome trim on the outside of the boot, like mine has you will not be able to push the light assembly out as the chrome trim stops you from doing this:mad: to get this chrome trim off is very hard, why make thing so hard.
B
Ben2057
North Wales
Has anyone else on here managed to remove the light assembly without removing the chrome trim
