racall
- Nov 24, 2003
- Age
- 76
- Location
- london
- c class and slk
Just found this.
2011 VOSA changes to MOT
Still 13 months away until these new regulations come into force, but some interesting changes. From MOT from December 2011, the below changes will come into force, which will be very bad news for some.
HID lights – Specifically those aftermarket kits that give the very bright headlight beams. Any cars found with these kits will be an automatic MOT failure. Testers are able to easily spot the difference between HID kits, and manufacturer fitted Xenon’s. Easy to spot as Xenon cars have suspension level sensors, in car beam adjuster, and usually headlight washers.
Chipped ECU’s - Unsure of just how/if this one will realistically be enforced, but any cars with chipped ECU’s will in theory be an MOT failure. I can only assume VOSA have found an easy way of checking ECU software through the cars OBD port (diagnostic plug).
Wiring harness – The general condition of he wiring harness will be checked to make sure there is no rubbing or chaffing, and that the harnesses are in generally good condition. If unsecure, or damaged again MOT failure.
Airbag warning lights - If any warning lights are illuminated, it will again be an MOT failure.
