Xenons or halgen?
Geol
Scotland
250cdi estate/2009/2159
How do i tell if my C250 estate 2009 has xenons? My dipped beam bulb has just went out . Thanks
whitenemesis
CLS55 AMG '05
Do you have a thumbwheel adjuster on the lighting switch panel? Then halogens
Do the headlamps dip and raise when you first turn them on and no thumbwheel? Then xenons.
There would also be high voltage warnings on the bonnet slam panel if xenons fitted.
Naraic
2005 CL500.
If you look at them (when they're on), they are very white, with maybe a hint of blue.
Miffy
Bromley, London
CLK 320 CAB Elegance C208
you can get 6000k Halogens also so the colour is not a good indicator of bulb type
