j4gg4
- Aug 14, 2008
- Location
- United Kingdom
- CLK, CLS, A-CLASS, ML
Ok i opted for a pricey rather than a cheap aftermarket xenon kit which was fitted 4 months ago, been fine till now (past week during this cold spell)
FAULT 1...
With headlight switch on '0' (zero) when i put the key in the ignition and start the car... The headlights come on regardless of it being night time or not. Switching the headlight switch does not turn them off. The only way they turn off is if i take the key out the ignition.
To get BOTH headlights to work i have to turn the headlights ON with the key OUT then start the car(i have to do this a fair few times to get BOTH headlights to come on) after ive done this.... 1 headlight ALWAYS goes out after 5 minutes. (1 or the other) seems like they cant run together anymore as a pair.
As if that wasnt the least of my problems....
FAULT 2...
I swapped my sidelights for some halfords sidelights. It triggered a malfunction on my dash and with all lights OFF they stayed ON regardless. I took them back to halfrauds and i bought myself some off ebay with resistors designed for my merc. Fitted 1 side OK works a treat. Otherside does not work AT ALL, Tried ORIGINAL sidelight bulb doesnt work. Tried known working bulb from other side DOESNT work. Erm... how do i get it working again? seems its triggered some fuse? or some sort of cut off switch or something? Could taking it to merc and getting them to reset something solve this? Im just worried with getting charged £100's and £100s over a poxy little sidelight bulb! this has gone on for almost a year now and its INCREDIBLY frustrating. Luckily i havnt had a ticket yet for this.
Suggestions on what to do below pls? Your help on this situation would be HIGHLY appriciated as im completely baffled ive spend over 10 hours in total trying to figure this out.
FAULT 1...
FAULT 2...
