xexon bulb change
Medntee
Midlands
w220 s class
hi
changed my xexon bulbs on my w211
managed to get old bulbs out and new bulbs in (with only about 18 cuts on my hand, there is no room in there!) however i can not seem to get the light ignition
part to go on properly, it will not twist and lock. is there a nack to this?
thanks
kristian
Is this the cap on the end
Naraic
2005 CL500.
Xenon
V6Matty
Newark, Nottinghamshire
Kristian, yep they are a pain to get back on and your not the only one who hass the problem, it took me about 45 minutes to change mine and I'm what they call an athletic build (just another way of saying flipping skinny in my mind lol), may be worth trying to put it on and off a couple of times before having it in the end position just to practice. Where abouts are you in the midlands?
Medntee
Midlands
w220 s class
hi
am in leicester.
it sits in the groove but just will not turn
V6Matty
Ok Leicester isn't to far from me and if you were to come up to Newark at any point I will see if I can help. I fount the unit to be very stiff what re attaching almost to the pont I thought I was going to break it but it worked fine in the end?
Medntee
Midlands
w220 s class
thank you for the offer much appreciated, if a passing soon i will let you know
thanks again
Suki
Berkshire
W251, S211 320 cdi Avantgarde (2005), W202 250 td (now sold), W245 with lots of extras
i had the same issue. In the end I removed the headlight!!
