yellow battery warning light
curlyman
e class 220d 4matic estate
hi anyone know what this warning light means see photo 18 plate e class only bought car 2 weeks ago ? cheers TIA
malcolm E53 AMG
Probably a good time to check the voltage on the car battery it should be circa 12.6V if it’s below 12.4V use a trickle charger to give it a boost. The battery may need changing as it’s six years old if it drops below 12V
Srdl
New Forest, Hampshire
GLC43 AMG 2018 (X253)
Either battery getting old or you’ve just been running too much equipment with the engine off. Having the headunit on, using the radio or playing music will drain the battery quite quickly if the engine isn’t running.
