BillyBoy
- Aug 28, 2003
- W213 E400d All Terrain
Following on from this thread:
http://forums.mercedesclub.org.uk/showthread.php?t=49841
I had a new fan fitted (non-MB), which went ok for a couple of months, then it failed - The fan was coming on full speed whenever I started the engine. The diagnosis from Malcolm, myself and a garage all concured and pointed to the fan control unit. Took the fan back to KMS where I got it from under warrenty and exchanged it for another. Fitted this back in September and it was fine until Tuesday when the same fault occured. Fan now doesn't run, but I do get an error on the dashboard telling me the fan has a fault (interestingly this didn't happen with the other the fans when they failed).
Question is, is there any underlying issues anyone knows of that can cause this? The first fan was the original as far as I know and it is conceivable that this did fail after 5 years and it failed by not operating rather than running full power, however for the other two failing so soon after fitting, though possible, seems unlikely.
It could be coincidence and possibly a bad batch from the manufacturer, but before fitting yet another fan, I want to try and rule out an underlying problem with the car.
Cheers,
Bill
Cheers,
Bill
