Help needed! C180 Kompressor 55reg W203 auto
Dave wood
Dave wood
Mercedes C180 Kompressor 55reg W203
  • #81
Also pics of the connectors to ECU to rule out contamination
Sent from my SM-G935F using Tapatalk
Arudge
Cradley Heath
CLK200 2000 Kompressor
There's a lot to go here, I'll go onto more detail later. Although Snapon kit is not much use on a Mercedes, we will do what we can.
Dave wood
Dave wood
  • #83
Ok I look forward to hearing coz this is a royal pain in the arse lol.
Many thanks Arudge
Dave wood
Dave wood
  • #84
And the one I forgot to upload
Arudge
Cradley Heath
Firstly, the alternator warning lamp on the dash, this ties in with the voltage reading of 14.18V on the Snap on device. This voltage reading is a little low, we should be looking at 14.40V leading me to suspect poor earth connections, possibly the main engine to chassis earth strap or poor connections on the battery posts. It could be a faulty regulator within the alternator but dropping just 0.2V smells more of poor connection to me. Earth straps do fail, you can't clean them, the problem is within the crimp itself, you can only replace them.
The P codes offered by the Snap On device don't seem to correlate with Mercedes P codes so we will just run with the text descriptions.
Crank Position Sensor.
Always something to worry about. They usually just drop dead leaving you stranded at the roadside. The CPS controls the entire ignition system and without it you have no ignition system. The do fail and in my experience have a 10 year life expectancy, if yours is dying it would certainly give you misfire, but normally they just drop dead leaving you with no engine. They often work again when cold only to die when they get warm.
Fuel trim.
Your fuel mixture is all wrong because.............
Manifold pressure
Your fuel mixture is all wrong because.............the manifold pressure is wrong because you've got a leak. I know it says pressure but it really means vacuum. It becomes pressure when the supercharger comes on line. Remember, at low rpm the inlet manifold is under vacuum as the engine draws air, the vacuum turns to pressure as the SC starts pumping air. Either way, the map sensor on the manifold isn't seeing the pressure it expects to see. Some would say the sensor is faulty, i'd say you a have a leak. Could be a loose pipe or connection, there's lots of them. On mine there's a vacuum operated valve that allows air from the manifold to the exhaust system to superheat the exhaust on startup, they stick.
Then there's the cam chain and it's adjuster which can screw everything up.
I've had all of these issues on mine and good few more. I suspect your misfire isn't just one issue but a collection of issues, all of which are common to Mercedes.
I know it's not what you wanted to hear, and only a STAR diagnostic can be more accurate. You may be better off with a Honda!!
Andy Rudge
Dave wood
Dave wood
  • #86
Fuel trim.
Manifold pressure
Andy Rudge
A Honda please Arudge don't swear at me again, it's not polite! Lol.
Right well it's not what I expected but it is if u know what I mean!
Earth wires no problem I will check all earths to rule that out!
I've also got another fault come up on the dash and that's the rear number plate bulb! But it works!?!? (Electrical fault)?!?!
Firstly i know this wasnt mentioned in ur responce but in ur experience do u think I can rule out the loom? If so I can completely forget about that!
Moving on vaccum leak right ok so that in its self is going to be a pain in the arse lol. So it's really a case of taking everything off the engine checking all areas for possible leaks, remove every pipe and manually blow smoke through to eliminate any hidden holes! If no holes in pipes then it could be a connection point, gasket or link that's leaking! I've already checked the vaccum on the pump and the servo and the vaccum is strong!
It can only leak somewhere along the vaccum system right, so what would be the best route of elimination to do this?
Just a question! When I replaced the sensors 1 by 1 earlier is it a must to clear all codes for each time I replaced a sensor and started the car to check if issue was resolved, or would it not have mattered as the issue was solved and the engine management light and codes still being present wouldn't affect it?
So after your advice it looks like I'm going to need to take it apart (AGAIN) LOL.
In complete honesty the frustration of this issue is a pain but I am enjoying being under the bonnet lol.
Also my engine is under warranty! The big thing is that if it's the chain then they check their engines (so they say) before they are sent out! Now the word (CHECK) that's quite a loose word! Now do they start the car and if it starts and seems to run ok then that's good to go! Or do they thourghly check it with more attention to detail! As far as I'm awear they have good reviews but that's not everything!
What do I do? What would u do? Lol
Clear codes after every change you make. Some codes won't go away till you have three successive long runs (a long run being a certain number of minutes at normal temperature) and that will also mean the light may not go out.
star
Reading
Smart + others :)
Faults will clear down 1st time with a star machine unless it’s a current fault.
Dave wood
Dave wood
  • #89
Ok got ya! So If the codes ain't cleared even if the sensors have been replace and the issue is resolved when started the engine would still run like crap unroll codes are cleared?
Dave wood
Dave wood
  • #90
Also will a star be able to tell me electronically if there is a vaccum leak?
Arudge
Cradley Heath
The loom.
Sorry, i forgot about the loom. The oil in the loom is another Mercedes issue and as Star pointed out, is restricted to the engine bay with the most damage done when it gets to the o2 sensor, the oil contaminates the sensor and ruins it. That would throw a code of it's own. The oil originates from the cam magnet and there's a fix for it, as again Star has mentioned.
I had oil in the plugs and it causes problems as LK has described, yours look clean so they should be ok.
However.......
You have a CAN error. Controller Area Network. This is a high speed digital network that connects the various ECU's together. You have a break in the network which is almost certainly a dodgy plug, again we are looking at corrosion or oil contamination. I don't know what information is carried on the CAN line in your car, but i'd put it high on the list of things to sort out. The CAN line is easy to spot in the loom because its always a twisted pair. So if you see two wires twisted together that's your CAN line. There twisted together to reduce outside interference. I think the CAN line starts at the ignition switch and covers items like the ignition, abs, traction control, climate control and stuff that needs lots of data from sensors.
Vacuum testing.
I'll cover this later.
Engine warranty.
If it starts, runs, doesn't bellow smoke that's as much as you can expect.
Dave wood
Dave wood
  • #92
Why Can't U live nearer to me! Lol
Dave wood
Dave wood
  • #94
The loom.
However.......
Vacuum testing.
Engine warranty.
Ok right so that's a lot to deal with!
So a star it has to be! This I take it would give me a more accurate information of problems? Or would I pretty much get the same result but with different codes?
Other than that I guess the thing to do is actually pull it all completely apart checking everything! And possibly replace the loom then that would rule out that! I could then focus on the rest, sensors, vaccum, gaskets, chain ect...
Arudge
Cradley Heath
index.php
You can see the oil in the left connector block and the corrosion in the right block. This is what we're looking for.
Arudge
Cradley Heath
A STAR machine and a skilled operator are worth their weight in Gold. The depth of analysis is incredible but it's not a cure all, but it will save you a lot of time, and i think this job is going to take a lot of time.
Dave wood
Dave wood
  • #97
index.php
Many thanks Andy.. I'll be sure to check every plug and connection to see what's there.
I'm in 2 minds whether to just get the timing chain and out the way and then at least it strikes that off the list and also could resolve the issue.
But then I still have the vaccum issue and or extras to add to it.
Dave wood
Dave wood
  • #98
Yeah I agree the star is definitely the way forward! Dose anyone know or recommend someone around the RM10 area?
Yeah I kind think this is gonna go on for a bit but I hope to get there sooner rather than later
Arudge
Cradley Heath
I'd be more concerned about the crank position sensor. Did the crank position sensor show on your mates basic reader?
Dave wood
Dave wood
  • #100
No it never showed CPS, it only showed a multiple misfire!
