HELP!!! no fire to cylinder #3 and #6
drmw
Yorkshire
www.autonomed.co.uk
I understand that - I saw it.
What I am saying is I don't think that should be the case.
I may be wrong
L John
W204 C350 Petrol Elegance
I think I know where the problem is but I wouldn't want to offend you again.
OK, I'll try again...
Mr Angry Meabon, you posted a photo of the distributor cap but the base was also in the photo post number 28 on the thread.
http://forums.mercedesclub.org.uk/showthread.php?t=133317&page=3
The base part of the distributor (not the cap as you've changed that) is crudded up at the bottom and is likely to be tracking to earth. The two crudded areas are at position #3 and #6 so my guess is theres tracking to earth here causing loss of HT to the plugs.
I've cropped and enlarged the photo
Clean it up with WD on steel wool, don't use water.
Let us know if it worked.
M
Mr.Meabon
huntington wv cabel county
190e 1991 6cyl
  • #83
ive taken off the base cap that the rotor cap goes on took of rotor and the mount that holds rotor arm cleaned it very well and brissle brushed till it was almost new looking basically taken off a few layers but there is a rubber seal that seemingly water couldnt get through i still tryd to get it off but it seems as i would damage it maybe bearings im guessing is whats behind it idk maybe i should try taking that off with some wd40 ill have to pick some up or maybe u can inlightn me about whats beyond that point cuz maybe i dont have to take that off since its seald off and it wouldnt matter for spark earthing out cuz its under the base cap and is hidin from ruining the spark idk i could be wrong
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Ive not bothered to read this properly as I couldnt follow the text without having to stretch my eye balls.
But if it was my car I would buy a new dizzy cap, rotor arm, leads and plugs from Mercedes and then she how she runs from there.
jib
M
Mr.Meabon
190e 1991 6cyl
  • #85
jib
bub ive done that as i stated like 20 times on here and in the videos on here that ive posted ill post them together but it woulda be easier to read but people keeps asking same questions as the others an now my thread is way out of hand
drmw
Yorkshire
www.autonomed.co.uk
In which case and with all respect to the OP, I'd get someone who knows what they are doing to fix it.
I very much doubt it is a complicated problem and if someone can actually get hands on as opposed to trying to interpret difficult posts, I imagine the problem will be fixed quite quickly.
I am now out of this thread.
M
Mr.Meabon
190e 1991 6cyl
  • #88
i know what im doing bub its not rocket science and yes i have had mechanics look at it they are baffled it has to be something simple you guys have seen videos im always opened to ideas as long as they have todo with the spark not vacuum lines an fuel that not my problem i have exchanged leads like u said n stuff and still nothing **** ive even tryd it multiple times i guess i have to make u people step by step videos on everything im doing cuz you guys seem to not believe me WHATS THE DEAL like 9 pages and no resolve either i have demons in my engine bay not letting me get her fixxxed or im getting wrong info forget the compression tests forget vacuum lines for get any thing with fuel forget the ovp i washed it she ran perfect moments befor now #3 and #6 aint firing something got wet and broke im not a damn retard this **** aint hard todo i really wished one of u lived near so u could jus see its none of them problems this is now a rant because i hate when people dont believe me i for now will make videos to show u what i see
jibcl500
Cambridgeshire
CL500,ML55,SLK280
So without me having to read everything (cant be bothered) have you replaced as I mentioned before all the parts?
That rotor arm if thats what your still using is way past its best and needs to be replaced. Ignition parts as mentioned need to be purchased from Mercedes as other parts from other manufactures can sometimes be of poor quality.
Huntingdon is that Cambs??
jib
V6Matty
Newark, Nottinghamshire
about 30 minutes from the centre of Cambridge Jib, you fancying a trip are you lol
toby1
West Berkshire
From the USA I think. Not sure English is his first language though
Frontstep
T210 320cdi
Can I be confused ?
The rotor arm does not look new to me or even clean .
I assume water has somehow been forced down inside the distributor too.
It is very frustrating I understand, but I think most of us are just trying to get the dam thing going.
V6Matty
ah yeah your right, from West Virginia. tried google maps for directions there, oddly enough it didn't bring anything back :confused:
M
Mr.Meabon
190e 1991 6cyl
  • #95
jib
lmao guys good luck on trip im in huntington wv in usa thats alil far dont ya think an i got a new vid that should weed out alota stuff and lets u see what i do plus i cleaned it all used wd40 bristle brushed it all jus after video and guess what lol nope no diff still runs shatty cuz still not getting fire to #3 an #6 an jus to show you guys that my parts are new its all new from mercedes except the rotor roller but regardless where parts are from new and old i still have some problem
jibcl500
Cambridgeshire
CL500,ML55,SLK280
I think as you call it your rotor roller or as we call it here the rotor arm ! is shagged, knackered, kaput, Fu$%ed and needs to be replaced.
Then I think you might find your problem goes away.
Booked my flight see you tomorrow,!!
jib
M
Mr.Meabon
190e 1991 6cyl
  • #97
Can I be confused ?
no what u seen in pix are the old junk youll see in new video but any how since im going through and making videos can u guys atleast like them id greatly appreciate that as i would for you id even subscribe so that being said if you have a youtube account send me links guys ill like and subscribe even if we've had bad words im not mad at ya jus want my merc running in top im in love with these 190e's truly a great built car and super fun in the snow but vids uplouading to youtube now soo be on shortly fellas
M
Mr.Meabon
190e 1991 6cyl
  • #98
jib
nope not my problem youll see and ok ill order a stuff crust deep dish pizza and hot wings when ya get here
M
Mr.Meabon
190e 1991 6cyl
  • #99
and actually we call it a rotor button lmao but talking to you guys ive heard a few other names for it we call it that cuz the button part of the cap goes in the rollers hole yea stupid i know youd figure the cap be called a button since its the part with the button on it hope u know what im talking about :lol:
Tel: 020 8863 9233
