Key will not turn...
barbeds
cheshire
c240 elegance estate/2000/2.6cc
Eddie not to worry buddy. good to know your problem is almost over and you will be on the road soon. Did you see the clips on youtube about removing PCB from the key case ?
Aleem, yes I took a look at you tube and it looks just as I thought, hopefully I will never need to open it again once I get it back from Malcolm.
If I get it to work I can return it with the catch off and a spare strip to use with the new case, then it will all just slide out.
Aleem
Ok, let me know when you get it working and to order a new case. Thanks
Well I have fixed it, and all three buttons working, it is not in good shape so look after it.
I have fitted a nylon block with the catch removed, this will mean that it will just slide out when you get the new case, no knife needed. I have fitted a case 10 x better than yours was. I will enclose a new nylon block.
The next thing is there were CR2032 batteries in the key, you cannot use them as they are too fat and strain the case and PCB. You can only fit CR2025 batteries, I have put two in but I do not know the age of them. also fitted another battery carrier as the old one all strained
If got the same labour rates as Mercedes I could buy a new car after repairing a few of these keys ;)
Aleem
lLOL.. maybe not a new car but certainly can make very good money. Thank you so much for your efforts. Please pm me your e-mail address for payment. Should I Go ahead and order a new case ? and Once i get new case what batteries should I use, CR2032 or CR2025 ?
Only the CR2025, never the 2032, they are too fat, the batteries I have fitted are used, but voltage OK so no panic there
Aleem
Malcolm, you have not mentioned should I place an order for the new case ? and also awaiting your email.
Wait till it comes back and all working, then get the case.
I have sent details and address
Thanks it will get posted back in the morning :D
barbeds
cheshire
Hi Malcolm, whats the latest on my key.
OK no probs, thanks Eddie.
Strange that I have loved every working day of my working life from 1950 till 2000, these days I hate going in there, its a kind of history best left in the past.
Your key will be the last one that I fix, as all parts used up, so the end of me fixing them.
I have fixed your other key, One of the photo cells was missing and I have replaced it.
The case I have fitted is not wonderful, but OK as a spare, you could fit a new one.
You could if you wish buy a new case on Ebay and have it delivered to me, and the whole thing will still cost less than ¼ the cost of a new key, the PCB in yours is in good shape
barbeds
cheshire
Thanks Malcolm, no problems, I will just be keeping it in my draw as a spare, so as long as it is working that will be fine, you can send it back to me, thanks. Eddie.
Yes I will do that,, can you please Pay pal me again.
