- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
I also think that maybe its because left footwell/X3015 and rear/X3017 are not directly connected to each other?
I did test the line on passenger side and that was a solid 12V also.
The diagrams shows how everything is connected now, that works, I think whether you connect in the rear or in the right/driver footwell, you will end up with a setup shown in the second diagram:
look at the picture I put up in about post 15, they are all in parallel, you are now plugged into the same wire that was on the passenger side, and you are on the other end of it.
