mshah70
mshah70
Mercedes w211 2007 E220 Cdi
  • #21
The kit has arrived.
I have a question, according to DAS i need to enter the number of graduation lines on the bottle(from original tester kit) after the test is complete.
Does anybody know how many ml is 1 graduation line from that particular bottle shown in DAS. so i can compare it to my bottle, and use DAS to do the test.
Otherwise i can follow guidelines above.
mshah70
mshah70
  • #22
Test result
Injector leak off test
Under idle:
Injector 1: 50ml
Injector 2: 48ml
Injector 3: 50ml
Injector 4: 48ml
Under full throttle:
Injector 1: 38ml
Injector 2: 36ml
Injector 3: 100ml
Injector 4: 36ml
So i take that injector 3 needs replacing?
Test result
Under idle:
Injector 1: 50ml
Injector 2: 48ml
Injector 3: 50ml
Injector 4: 48ml
Injector 1: 38ml
Injector 2: 36ml
Injector 3: 100ml
Injector 4: 36ml
I would agree with that.
mshah70
mshah70
  • #25
Thank you guys for all the advice.
It was really helpful.
Westheath
South London
Test result
Under idle:
Injector 1: 50ml
Injector 2: 48ml
Injector 3: 50ml
Injector 4: 48ml
Injector 1: 38ml
Injector 2: 36ml
Injector 3: 100ml
Injector 4: 36ml
Did you clamp off the injector spill pipe return feed ?
When you remove the injector number 4 spill pipe injector connector
you need to clamp off the fuel return.
Believe it or not I've had some strange test results not clamping off the return on some engines.
Step 4 in this link.
http://pmmonline.co.uk/technical/common-rail-diesels-how-to-undertake-a-fuel-return-flow-test/
mshah70
mshah70
  • #27
I did not have a clamp at hand, but i covered the ends of the connectors with plastic caps that came with the kit, a bit of a loose fit, however when running the engine i kept a close eye for fuel coming back out of the connectors, lukily there was no fuel coming out of tge connecters.
Now my question is, are the clamps put in place ‘solely’ to stop the fuel coming back out?
And just say there was no fuel coming out, and no clamps in place, does that mean the test was not ok?
Or isit the case that ONLY if fuel comes out that it can have an effect on the test results?
bembo449
gainsborough , lincolnshire
I think your test was ok and an extra clamp would not have changed anything pal but I think westheath is rightly sharing is experiences with regular dealings on spill testing , if you are refurbing the set then it doesn't really matter anyway right ?
mshah70
mshah70
  • #29
mshah70
mshah70
  • #32
Guys just wamted to know, do i use a flat reamer or an angled reamer to clean the injector seat on merc e220 w211?
Westheath
South London
mshah70
mshah70
  • #34
Westheath
South London
Too far from me to help.
The cleaning kit from MB has tapered brass plugs for the injector nozzle holes so nothing can enter the cylinder during clean up process.
A wood dowel with emery paper glued on the end can do the same job polishing the injector seat.
mshah70
mshah70
  • #36
I have successfully changed the injector today.
After replacing injector suddenly i can hear my fuel pump making sound, sounds like theres air in the system and makes a knocking sound from the rear seat.
Any ideas any1?
Westheath
South London
Purging the air from the fuel system after the repair.
Also............
Check for leaks on fuel hoses, connectors and leak off pipes.
mshah70
mshah70
  • #38
Also............
Would u be able to direct me in how to purge the air from the system?
mshah70
mshah70
  • #39
Also............
The injector cleaning brush kit u mentioned, i managed to get it slightly cheaper from the main dealers. Its a very good kit.
mshah70
mshah70
  • #40
I opened the fuel filter inlet pipe to get air out of the system, but seems like nothing came out.
Fuel pump still making knocking sound. And can hear air travelling through.
Please help
