Westheath
South London
Make sure there's fuel in the saddle tank both sides especially the drivers side.
mshah70
mshah70
Mercedes w211 2007 E220 Cdi
  • #42
mshah70
mshah70
  • #43
My car just went into limp mode again.
I done a leak off test and i can see injector number 3 spitting out fuel, lots of air looks like.
What should i do
What should i do
Was the injector second hand or new?
Westheath
South London
Or refurbished ?
Check the leak off connector on top of the injector has the seal intact.
Check everything that you removed or touched when doing the injector.
Or refurbished ?
Yes, also check to see if you have the old style plastic t connectors as they can crack. Check the others to ensure they aren't leaking air.
mshah70
mshah70
  • #47
It was refurbished. Im thinking can it be the injector itself. I will take it off tomorrow and take it back to them.
Can i post a video on here?
I checked all lines and everything on the engine bay, when the old injector was in place, the leak test was smooth. However after the refurbed injector fitted, that particular injector is blowing air into leak line, other injectors are fine.
I will update soon as refit that injector.
Other than a leak in lines, i dont see any other way for air to get in other than the injector itself.
Could it be an open injector?
mshah70
mshah70
  • #48
Or refurbished ?
Yes i put everything back as it should be, no leaks / cracks visible
mshah70
mshah70
  • #49
Why is air only blowing through injector number 3 and not the others. Can it be the injector?
It must be, there may be a hairline crack down the body, some refurbishers miss that. I do not see otherwise how you get air on the leak test, unless the leak tester is having trouble sealing with the injector.
mshah70
mshah70
  • #51
No dont think so as i used the leak tester on that injector before.
Basically he took my injector and said he replaced a valve inside.
mshah70
mshah70
  • #52
I cracked the nut on that injector to try an bleed some air, but fuel only spouts out.
mshah70
mshah70
  • #53
The injector is leaking back the same amount of fuel as the other ones. But the difference is its spitting the fuel with lots of air.
So im not sure what to make of it
Buy an injector on ebay, euro car parts, dealer etc swap it out and see if it does the same.
If so, take it back to the refurbisher and get your money back.
Who did the work?
Don't do that on a common rail diesel. At best you will loose fuel, at worst high pressure diesel will cause a horrible injection injury.
mshah70
mshah70
  • #56
Who did the work?
Do u mean who refurbed the injector? Or who fitted it on?
mshah70
mshah70
  • #57
I was careful to only loosen it a little bit, does the system automatically bleed air through high pressure pump?
Yes and through the low pressure lift pump.
mshah70
mshah70
  • #60
Who refurbished
Its a company called ‘fuel injection Seevices’ in Cardiff.
I just spoke to the guy he said to bring the injector in, he will have a look.
Im thinking if this injevtor is leaking back the same fuel as the other ones, does that mean theres no problem with it in the eyes of the refurber, although its leaking alot of air through it?
www.ckinsurance.co.uk
