W211 Parktronic sensor problem
cem
New Registration
2003 w211 270 cdi avantgarde wagon
Hi Malcolm,
Same problem with parktronic here with my 2003 w211 wagon E270cdi avantgarde. No clue whether it is front or rear one, nevertheless some instructions how to replace sensors would be very helpful.
Details sent, you can edit out the address
Peter Sundberg
New Registration
Helsingborg, Sweden
ML500/W164
I have the same problem with my parking sensor, have ordered one but i need help with removing the cover under the engine.
Very greatful for you assistant
Best regards,
Peter Sundberg
bluespit
Chester, UK
W204 220cdi sport
Just read all the above but I'm no clearer. My rear parktronic is very hit and miss, only one sensor picks up anything and then only at about 1/2 metre. Remove and dry? How?
2009 w204 estate
Cheers
2009 w204 estate
Gr.uk
Cheers
I have sent you the fault finding guide, let me know if you get a bit nearer to working it out
andy 1964
sussex
CLK 350 Conv
Hi Malcolm,
Please can you send me details of how to remove or check sensors on my 209 clk350
andyskipper1964@gmail.com
Parktronic has occassional hick up with red bars on display and then clears after a while.
Manythanks
Andy
All sent Andy
Rob1949
Weymouth, Dorset
C270 2004 2.7
Have similar issue with c270
I have similar prob. with the sensors on my 04 c270 estate. I also assumed it was due to weather. My sensors turn themselves off. Button lights up. When I attempt to turn them back on, get the red warning lights and the be-e-e-e-p. However the problem is intermittent. Once the weather improved, they appeared to work correctly. Just when I thought things were ok and had sighed with relief it kicked off again!!!
Rob1949
Weymouth, Dorset
C270 2004 2.7
Hi Malcolm,
Can I tap the 'font of knowledge' again and ask if you have similar instructions for removing parking sensors on 04 C270 estate?
Rob
Yes I do and I can send
craigkirk
New Registration
North Yorkshire
E320 CDI Avantgarde Estate
E320 CDI Estate Parking Sensor Problem
Hi Malcolm,
Have been following this lengthy thread with interest - as I have exactly the same issue with my car. I would be grateful if you could email any literature you have on how to test the sensors etc. I have managed to remove all of them individually, noting mine are a mix of the 001 and 004 variants. Interestingly, after removing and reseating all of the them, the parktronic system appears to work intermittently - which is more than I had before with the 4 red LEDs on both the front and rear lights.
Grateful if you could help with the docs, as my specialist Mercedes Benz garage have charged for STARs diagnostic and have potentially suggested a CAN problem, but aren't sure - so they want to investigate - and I can just see the spiralling bill should I let this happen without following some of the advice in this forum first.
Email is: craig_kirk@hotmail.com
Craig
I have sent what I have Craig :D
shatter
Worcestershire
ML320 2006 3.0D
W164 320 CDI 2006
Hi Malcolm,
This is my first post hope you can help.
I believe I have a Parktronic sensor problem at the front of the vehicle, usual thing red lights and bleeps, the rears seem to work fine. I have been following this thread and have noticed not many posts from M Class owners. Please can you send the document to check the sensors out, my email address is timothy28@sky.com
Many Thanks.
Tim
lespaul73
New Registration
Italy
W211 -E200- 2004
W211-E200-2004 Bumper strips removing
HI Malcolm,
I've got a similar problem with my W211-E200-2004. Could you please send me the details to get to the sensors? Rear and front please
Many Thanks,
Rocco
lespaul733@gmail.com
Tobbe
Sweden
W211/05/320
W211 2005 PDC problem
Hi Malcolm
After spending to much money on my mechanic i hope to fix the pdc-problem myself.
I wonder if i can take part of the famous document that could help me fix that anoying bleeep at the dashboard:mad:
Many thanks in advance
Tobbe
Lee_E320
London,UK
E320 - 2007 - 3 litre diesel
Parking Sensors playing up.
I think I turned them on and turned them off, now they keep turning themselves off, with a long beep and only the red lights flashing.
I have tried turning on and off again, I have been round and looked at the fronts of each of the sensors they seem clean enough. Seem to be having a rough time with my new car... :-(
Hi Malcolm,
Many Thanks.
Tim
Are you still waiting this info, just seen the post
