W211 Parktronic sensor problem
Hi Malcolm
After spending to much money on my mechanic i hope to fix the pdc-problem myself.
I wonder if i can take part of the famous document that could help me fix that anoying bleeep at the dashboard:mad:
Many thanks in advance
Tobbe
Hej Tobbe,,just seen the post, to start with I can send the outline faults details
I think I turned them on and turned them off, now they keep turning themselves off, with a long beep and only the red lights flashing.
I have tried turning on and off again, I have been round and looked at the fronts of each of the sensors they seem clean enough. Seem to be having a rough time with my new car... :-(
I can send you the details of a few things to check
And sent Tobbe it gives an outline of what to look for, you can edit out your address
gez
South Coast
R230 SL350; R231 SL400 (SOLD), W211 E320 CDi Estate (SOLD), R129 Brabus SL500 (should not have SOLD)
Hi Malcolm,
I also have a parking sensor problem on my W211, could you please send me a copy of the instructions to
gerry.bond@ymail.com
Many thanks.
Cliff Calvert
Gosport
A Class A 150 Classic
A Class sensors
Yes that document shows how to remove the strip only,,that is why i sent it as well, its dated 18.09.01
Would you be so good as to send me the instructions on how to remove the sensors please. (calvert302@tiscali.co.uk)
Topple
Donegal, Ireland
E270 (w211), CLK 200K (A208)
Just bought myself an 05 E270 estate, the sensors were working when I bought the car now they, don't :-(. Been reading this thread with interest. All I get is 4 red lights at the front and rear then switches off.
Malcolm any chance you could send me the appropriate docs to check and replace the faulty sensor. Many thanks.
pdutton@hollyrise.com
matthewins
W211 E320
Hi Malcolm, guess what? Any chance I could have the diagrams for the parking sensor and trim removal please? See my profile for e-mail address. Many thanks in advance!
Hi Malcolm,
gercom
Many thanks.
Just seen the post and sent them. sorry
Sorry just seen this post,,, the fault guide I have sent, it could be bumper off to get to them on an A class
I cannot use that Email as I cannot attach thing to it
pom
This may not be a sensor, could be control unit but details sent
matthewins
W211 E320
Hi Malcolm, send to , W211, E320 CDI Estate. Many thanks.
OK sent what I have, you can edit out the address :D
Johnski
North Herts
I am probably the hundreths requester, could I have the doc describing change of rear sensors of a w211 280 cdi 4matic estate please.
M9PGR
Swansea Wales
CLK230k cabriolet
PLEASE,PLEASE, HELP!!!
What started as an intermitent fault is now permanant.
Parktronic activating when slowing down. also affects reverse sensors.
I have tried the following
I have cleaned the sensors (several times) result no change
Got it diagnosed on a 'autoboss' ?? system, showed 10 faults, cleared, problem remains!
Got it diagnosed at an independant Merc centre in Bridgend, no faults indicated and after a long test drive no evidence of fault!!! drove home no fault!!!
Next day fault returned with a vengance and now when it happens (continual) it switches the sensors off by the switch???
I am so frustrated I dont know what to do next and the car is up for sale and I do not want to sell it with a fault (W208 Convertable W reg 2000)
can anyone help??
liathach
Registered
Aberdeen
ML320 CD1 2006 3.0 diesel
Could I also please request info on how to investigate the front and rear parking sensors on my 2006 M-class?
My email address is lamont@mlamont.plus.com
Many thanks
V6Matty
Newark, Nottinghamshire
Hi Guys
Now that Malcom is not here for a while would anyone else be able to forward me the details, my sensors are intermittent (well faulty most of the time) and don't want to just have a go without some instruction for fear of breaking something.
matt.nears@dixonsretail.com
