I do not have a voltmeter however the battery is brand-new & fully charged, so I suspect connections, solenoid & starter motor, is that the right order?Looks like service B has been exceeded by 730 days.
Are the battery leads corroded ? What is the voltage showing at the battery ?
At least the dash lights up.
I'll make a start on the front wings.Now what are you going to do about the rest of it?
I wouldn't be tempted to start playing "parts darts" until I have done some diagnosis. Could be time to invest in a multimeter.I do not have a voltmeter however the battery is brand-new & fully charged, so I suspect connections, solenoid & starter motor, is that the right order?
Any links?I wouldn't be tempted to start playing "parts darts" until I have done some diagnosis. Could be time to invest in a multimeter.
The good news is a cheap £10 Chinese one is just as accurate as a £300 Fluke.
Any links?
Clean out those scuttle drains soonest, then take the cover off the bottom of the wiper arm and lube it liberally.
Was there a surcharge on the one you bought? The surcharge is usually refunded when you return the old one, often called "service exchange".So the new starter arrives on Wednesday. What do you do with the old one? Is it straight in the bin or can it be refurbished, if so how?
