04 e200 service brake
Willie
I am getting a white service brake visit workshop notification on my dash. Sometimes the dash says no malfunction and sometimes it says 1 malfunction..
If the brake switch was faulty would that mean the brake lights wouldn't come on (which they do )
If sbc pump is the problem can it be reprogrammed ( car is old but low mileage)
What should I look out for ?
Otherwise car in great shape
Thanks..
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Brake pads low possibly. ?
SBC timer sounds likely, it can be reset although much cheaper than it used to be to get it serviced - find a decent MB indie
W
Willie
Thank you for your help.
I've had the pads and sensors replaced and that job needed to be done.
My dash now says no malfunction but when I turn the engine on the visit workshop notice re appears.
I had the work done in a small local garage and I think they just don't know how to clear the dash ( good at the actual mechanical work though).
Any ideas on what I could do myself.
Tkx again.
V6Matty
Newark, Nottinghamshire
The SBC pump will have reached it preset actuations limit, depending on the error code read through STAR you may be able to have an update to extend the limit if it passes other tests (pump pressure and build time limits), after that then it’s a case of refurbishment of the pump and reset of the actuations count.
Please whatever you do don’t buy a reset dongle and just reset the counter without having the other work done, if you do the next time the pump runs it CAN fail, leaving you with 10% braking capacity (and no that % isn’t an exaggeration that really is what Mercedes’ themselves confirm).
onefortheroad
uk.
W
Willie
Thanks for that very good advice . I certainly will not use such a gadget as above. The problem seems to have been the pads /sensors which are now replaced. It's just a matter of clearing the dash now the work is done.
Thanks..
onefortheroad
uk.
Easy to clear for any garage tbh. A few ign cycles usually clears it if the sensors are located properly.
W
Willie
Can the malfunction be cleared off the dash without going to a garage.?
The car has just gone through and passed it's annual rest.
Tkx.
V6Matty
Tkx.
Brake service and break wear are two different things, this won’t fix itself, with a general code reader you can try resetting the error but it will come back,
