129 roof problems
eggy91sl500
91sl500
Just bought a 1991 500sl, tried the roof, nothing but a clik behind drivers seat, so I tried the spanner to do it manually, in the boot one of the small red levers is missing, and the other is solid, do the rams ever lockup and not move. Any suggestions
Wearsafoxhat
Sunny Hampshire by the sea
Which roof are you referring to ?. The hard top has two locks above the sun visors that need releasing as well.
I assume that you bought the car with the roof not working or has it just packed up ??
E
eggy91sl500
91sl500
Sorry, yes bought the car like this.
I'm trying to get the hard top off.
Wearsafoxhat
Above the sun visors are little access points. Need to pop out the blanking plates and use the hex key in the tool kit or one similar, 8mm I think to unlock the two front locks.
Not too sure how you will sort out the rear ones if one is broken and one missing.
The key needs to be in position one and the roof switch needs to be operated within three seconds for it to begin its sequence, if you have not tried this. It will just click if not. Don’t forget to un plug the rear window heater cable too. Apologies if you already know this but thought I’d mention these bits Incase not.
6mm hex above the windscreen. They're tight to turn.
E
eggy91sl500
91sl500
Thanks, I appreciate your help, it's the back ones that are beating me,
