steve--o
hi all
mi old 190,d 5 cylinder has devoloped a core plug leak.
its under the exust manifold, on the block and its the first one in from the gearbox end of the engin.
the core plug looks diffrent to the standard,knock out,knock in type,as it has a hexegon nut head in the middle of the plug,ie so as two fit a socket on to unscrew.
just before i dive in with the spaners,can any body advise if it is indeed screwed into the block and if its a standard rh thread ?
many thanks Steve ,in a fizzin hot Almeria,layed under an old merc trying to get the down pipe off
,with mi mrs saying is the car fixed yet !
