190E Gear shift knob, How do you remove it?
Nencrono
30 miles W. of London
I want to swap over a leather gear shift knob into my car to replace the plastic one. Auto tranny.
How do I do this? I can't remove the PRNDL plate and get access to the brass coloured nut which seems to hold the shift lever. Once I eventually get that nut off, is that all there is to it?
Any advice/pictures most welcome by one of the mechanically inept.
TIA
the gear knob comes off the shaft, you never take the shaft out.
Malcolm
N
Nencrono
television,
Do you mean the knob itself unscrews from the shaft & can then be swapped over? I tried that and was using so much force to no avail that I thought I'd twist/break/damage something.
Forgive another silly question, but why do you never take the shaft out?
Nencrono said:
television,
Sorry I am wrong on your car, forgive me. go to
http://www.detali.ru/cat/oem_mb0.asp?TP=1
page 26 then 060 and you will see your gear knob. that cover you talked about has a clip under each corner and needs a hook to unclip it.
Malcolm
Tel: 020 8863 9233
