1987 190 E 2.3 16 Valve
panosafrica
Johannesburg
190e 2.3 16v
Hi all!
I need some information please regarding the specs required to set the hydraulic lifters OR tappet shims for the 190E 2.3 16 Valve please. We need the specs for clearance.
Thank you for your time and consideration
Panos from sunny South Africa
Ps I am not sure whether this car has tappet shims or hydraulic lifters
stwat
Sheffield
1989 300SE
As above. Hence why they sound line a clapped out diesel on tick over.
Here is the procedure.
P
panosafrica
Johannesburg
190e 2.3 16v
Thank you very much
I appreciate it
Blessings from Sunny South Africa
Could I ask you if you could please email it to me at kapa.pano@gmail.com
stwat
Sheffield
1989 300SE
Hi. I only have the image files that I have posted here, not any pdf files.
P
panosafrica
Johannesburg
190e 2.3 16v
Thank you all so much,
Are the valve clearances etc applicable to the 2.3 16 valve as well. The picture in the manual shows a 2.5 16 valve engine cover
Thanks again
stwat
Sheffield
1989 300SE
Yes they are the same. I have sent you the image files.
P
panosafrica
Johannesburg
190e 2.3 16v
Thanking you again
Yes I have receieved the images files
Thank you
Take care and have a wonderful day
stwat
Sheffield
1989 300SE
Once you have measured which size shims you need, if you can't get any from a merc dealer you can buy them from a Peugeot or Kawasaki outlet.
star
Reading
Smart + others :)
The shims are marked with the size to help.
