1990 260e
mr21again
Hythe,Southampton.UK
1990 260e will not start
Hi, Is there any one out there that could please give me some advise.
I have had this car for about 2 months running on lpg single injection.The car has been running smoothly,I am really please with the mileage i get running it on lpg.
The problem is that I ran out of gas also petrol as the fuel gauge dosn't work. I have put petrol in,but now i cannot get the car to start......I have found 1 vacum hose from the air filter but I do I cannot see were it goes to... would that stop the car starting ?? The car turns over but it will not fire up, the plugs do not seem to be flooded and there is petrol coming through the injectors but not much. I do have to change one of the ht leads over as i pulled one and pulled i out of its socket.I have tried to bog it just to see if i can get it started but it arc's over. Now I have no idea on what to look at next. So I would most greatfull if someone out there give some clues to what to do........... Looking forwards to hearing from you.
Many Thanks
Xtractorfan
S class
Dont you have to switch over from one fuel to the other..you sure its switched to petrol for starting ...other thing is have you put in enough fuel to allow the pump to pick it up. and thirdly have you checked the fuel pump is running/working ..
M
mr21again
Hi thanks for coming back to me, Yeah I have switched over to petrol, and i put £20 worth of petrol.
How can I check the fuel pump ?? is it located at the rear of the car ? I tried to start it again today with a fully charged battery, but still with no joy. I can smell the petrol and I can hear a motor running that might be the fuel pump. If I changed the ht leads and plugs do you think that would make a differance...... I have even though about towing the car to fill it up with gas to see if that would work. but other than that I do not no what to do.
Many Thanks Neil
