1990 W124 230e cooling fan query.
kraM
Berkshire
1999 CLK 340
Hello,
My car (above) has recently been getting warm in traffic (electric fan doing its job). The main fan spins freely, even when hot. I can easily stop it whilst it ticks over.
After much head scratching, I managed to get it off, and looking at it, it has a very simple bi-metallic clutch operation.
I've tested it with a kettle of boiling water. It didn't change shape.
Before I buy a new one, are these Bi-metallic, or am I being a biff, and they are somehow magnetically operated?
The only replacement I've found is about £120! Are they common parts to fail?
Thank you.
Mark.
Not sure about yours but some cars use a silicon oil that paradoxically gets thicker as it gets hotter.
Toyota do this on Landcruisers. Toyota do small bottles of the oil for repairs.
d215yq
Valencia, Spain
1987 W124 300D 280k miles
Aren't they all viscous couplings - had to replace a coupling on my W124 E220 so newer than yours so would assume yours defintiely has it? IIRC it was 40 for the part (not the whole fan) but I couldn't fit it myself so not exactly sure of the breakdown. My later E220 estate had the same problem and I just used the heater when sat in traffic for the whole time I owned it,..but neither of those had the electric fan, so it might be enough to just rely on that unless you regularly drive in queueing traffic, particularly now summer is over?
star
Reading
Smart + others :)
That’s not a bi metallic strip or viscous fan coupling. That is just part of the “clutch” that is enguaged by the electro magnet under the water pump pulley. This is switched on by the fan temp sensor set at 100’c.
grober
Scotland
W204 C200cdi estate
At 1990 the 230 will have the 2.3 litre version of the M1O2 engine hence the electromagnetic clutch like the 4 cylinder petrol 190
Bogus
Edinburgh
W124 230E 1992. BMW X3 2.0 d. X drive 2012
You probably need a new fan switch, cost around £10.
Its the switch they are messing with in this video
kraM
kraM
Berkshire
1999 CLK 340
Excellent, thank you very much, you've been a massive help (and saved a few quid too!) I'll be checking it tonight.
star
Reading
Smart + others :)
Two different switches, single and twin pole.
kraM
kraM
Berkshire
1999 CLK 340
After testing the loom, where both wires to the magnet go to ground?!? I pulled out apart to find no fault, gave the magnet 12v and it worked perfectly. Tested the switch and nothing (in the kitchen with the switch suspended in a saucepan of boiling water via a metal coat hanger, when my wife walked in...)
Switch now on order.
kraM
kraM
Berkshire
1999 CLK 340
Hi, all fixed now. For others with the same problem, it's the Red sensor (two pin) at the front of the head. There is also a single connector under the air cleaner and a bolted earth.
Sensor replaced, didn't loose more than a few drops of coolant.
Thank you.
Bogus
Edinburgh
Good stuff.
