1993 R129 300sl no start
Fleetwood
Horsham, West Sussex
2005. SL350
hi all
Haven’t been on here in a while as the merc (R230)has been running well
BUT ! I now have a R129 300SL that I’ve just acquired that won’t start, battery is good and well charged, turn the key and all lights on the dash light up but won’t crank over, if I jump the starter motor it fires up
Any ideas on what else it could be ?
You may have a bad neutral safety switch. Its located on the side of the gearbox and reports to the ecu which gear is selected. To diagnose it easily requires STAR
Fleetwood
Fleetwood
2005. SL350
Just changed that for a new one, also have changed the ignition just in case
Also it’s a 1993 so star wont work on this old girl
Yes it will.
Works fine on my 93 500SL.
It may also be a bad starter solenoid.
When you turn the key is there a click?
Fleetwood
Fleetwood
2005. SL350
Nope nothing, if I jump the starter she fires up fine so can’t be the starter, no power on the small wire to the solenoid
Thinking it could be the starter relay K38 but don’t know where it is
I don't think they had a k38 relay at this age.
From what I recall the power to the solenoid goes from ignition switch to neutral safety to solenoid.
Put 12v on the solenoid to check that works as well.
Fleetwood
Fleetwood
2005. SL350
If I put power to the solenoid she starts straight up, but don’t have power to the safety switch
Fleetwood
Fleetwood
2005. SL350
Do you know what wires go where by any chance . Got the cable off the ignition switch and power on 2of them
Power will only be present on the solenoid connection when the key is turned. It should be easy to identify by connecting a meter to each connection in turn, turning the key and looking for the one that becomes live when the key is in the crank position.
Fleetwood
Fleetwood
2005. SL350
Ok the girlfriend use turned up so have managed to work out what wire is the starter, ignition switch is working fine, but even when put 12v to the starter wire from the ignition she still won’t crank
Ok so do the same check at the neutral safety then 'just' trace the wiring
Fleetwood
Fleetwood
2005. SL350
Lol trace the wiring you know how theses cars are built, ok so weekend job is interior out
Thats why the just was in quotes! :)
I'll see if I can find a wiring diagram if I get the chance.
Fleetwood
Fleetwood
2005. SL350
  • #20
Lostkiwi any luck with that wiring diagram? Have double checked everything - power from ignition switch, no power to the neutral safety switch, if I put power down the safety switch she will start right up
So it’s either a relay somewhere or a broken wire, the cable at the neutral safety switch isn’t the same colour from the ignition switch
