adrianr
- Aug 3, 2022
- W124 E300 Deisel estate 1994 auto
Hello everyone.
Just acquired a 1994 Red E300 Diesel estate automatic.
The e300 Diesel has cream M tex interior and is in good nick for its age. Only done 82000 miles when I got her - and has covered about 17000 miles since 2006. I put another 500 miles on it in the first 4 days.
The previous owner cleaned out the intake (hateful EGR gunk), and had a new engine bay wiring loom made and fitted. All fluids (including the auto box) and filters changed. New tyres. new o rings on the fuel lines. new glow plugs.
Am now working my way through things.
In no particular order:
Washed twice, clay barred, washed a third time followed by a couple of coats of resin polish.
The car needs some front springs (sits low at the front). Ordered Sachs springs this morning and a spring compressor tool for the W124.
Working on the light rust inside the rear estate part windows (under the rubbers)
Small rust bubble near the back number plate, the front right edge of the windscreen and the front edge of the nearside front wing. These are all small patches that I’ll work through.
I will change the diff oil.
fitted a new poly belt
spent a few hours freeing off the sunroof - works fine now
spent several hours freeing off the seized back seat folding mechanics that were rusted solid.
new rad cap
new wipers
lubed all locks and hinges
lubed the wiper mechanism, which was getting stiff and a bit jumpy.
fitted new car mats and a rubber boot liner
looking for a new top hose for the rad (Mercedes no longer have them), the edge has gone soft because of the diesel leak.
I have new coolant to put in once I get a new top hose.
oils filters and fuel filters on the shelf ready to use
new thermostat is on the way
temp displays only intermittently
the warning lamp indicating a bulb out is illuminated - yet all bulbs are working
fixed the vanity mirrors lights on drivers side
there was a diesel leak from the top of the injection pump. I replaced the rubber seals and copper washers yesterday. that is an interesting job, especially when one of the springs decides to hide on an undertray for a few hours)
set the tickover a bit higher.
n/s/r passenger window does not work - ill strip that and see what it needs to fix it.
i have some diesel purge to run through the pump and injectors.
exhaust is a bit boomy - the rear box has been removed and a straight pipe replaces it.
I had not driven a W124 before. what a comfy car to cover miles in. I am surprised how well the non turbo engine pulls.It’s not fast by any stretch of the imagination but it moves long nicely.
These pics are the original advert pics.
new rad cap
new wipers
