1995-1996 W124 250D add turbo.
yhedmond
Hi everyone~ I am new in town~ nice to meet you all~
I hv a 95-96 W124 250Diesel, I want to ask is it possible to add a turbo to it? If ys, how much will it about, and where can i find a turbo.
Thank you for everyboby~
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
If it's a RHD UK car you'll need a turbo and injection pump, turbo inlet manifold & vacuum system and you'll have to fabricate an exhaust manifold & heat shielding to suit
The Turbo 606 is very different to the n/a version and even with the parts listed above you won't have a complete setup
I don't think this conversion is economically viable
Nick Froome
www.w124.co.uk
djb
uk
out of interest dont turboed engines have oil jets to the back of the pistons? along with different rings ,valve guide seals etc
or is that only in the more modern compact intercooled units?
Bolide
www.w124.co.uk
I think the piston design is different on the turbo 606 and would suspect that all the items you list will be different
Nick Froome
www.w124.co.uk
Y
yhedmond
Thank you everyone~ I think my idea doesnt work then~
But are there anything I can do to increase the power of my car? Because it dont hv enough power when it climbing up the hill~
Bolide
www.w124.co.uk
Make sure the carpet mat isn't trapped under the accelerator pedal and make sure that you are getting full throttle with the pedal on the floor
Then just rev the nuts off it. They like it!
Nick Froome
www.w124.co.uk
Y
yhedmond
I think my baby is getting old... he seems dun like runnin any more...
no carpet is trapped.. and i already kick down... Is it 95'96' diesel car is like that?
or are there sth wrong with my baby?
Other thing is my w124 sometime it vibrate quite seriously when i stop front of a traffic light with gear D, but it will stop vibrating if I change it to gear N or P.
Whats happen??
Bolide
www.w124.co.uk
Does the car shake when you start & stop the engine? I suspect the engine mounts are cream-crackered
The loss of performance at higher mileages with a 606 engine is caused by loss of compression. This is normally on cylinders #5 & #6 due to valve seat recession. The cure is a top-end rebuild. Budget about £1200
Nick Froome
www.w124.co.uk
Y
yhedmond
It only happen when the engine is on, and the car is stopped. most of time it happen when I just step on the break on gear D. but sometime even on gear P it will also happen~
I had change the engine mounts before~ but it is still the same~
do I need to rebuild the whole engine? or can I just change the cylinders #5 & #6 ?
I am not very familiar will this~~
Thank you very much~~
simon_wall69
Stone, Staffordshire
Could it be the tensioner on the belts causing the rattling? can be a common problem.
Re the compression; a garage will be able to test this, but you can be pretty sure a fair bit will be lost. No #6 cylinder on your car though, yours is an inline 5 being the 250. Remember, it was never a very torquey engine for such a heavy car, so even with top end rebuild it will still be slow.
Bolide
www.w124.co.uk
That's a fair point. I wonder whether the 605 suffers the same problem in the same back two cylinders as the 606? Or is it completely different?
I ran the old 250TD for 12 years. Great engine, revved well, very smooth - and a five pot!
The new E250 Diesel is a four-pot...
Nick Froome
www.w124.co.uk
simon_wall69
Nick Froome
www.w124.co.uk
The one that I had was quite flat so I would assume so.
ALFIEBEARD
DUMFRIES
JAGUAR XF-R SPORT
Turbo E250D
Hi I had my old E250D 124 Turbo Charged by TB Turbos of Lancs way back in 1996 when the car was a year old it really helped it and it ran far smoother once turboed. unfortunately it cost me the best part of £3000 and the centre prop bearings failed not long after. But it was still worth it at the time.;)
Alfie
