1995 C180 Overheating
GeorgeD
My car was overheating. I changed the t/stat which was stuck close (correct one replaced). Again the car was still overheating. I have also changed the water pump as this had a noisy bearing. Again still overheating. The ratio of anti freeze to water is 50/50. The car has a viscous fan, which appears to me to be working. The temperature rises fairly quickly to 80C and fluctuates between 80C-120C depending on traffic conditions. When the engine is switched off, after a couple of minutes standing, water is lost through the pipe at the neck of the radiator cap. For some reason pressure is building up. Any ideas please.
cobalt
overheating
Hi George
I have just had exactly the same problem it was a little RUBBER SEAL on the header tank it had gone really soft I bought a new cap £10 nop probs since hope this helps my car is a S280 but I imagine this part would be pretty much the same hope this helps.
John
G
GeorgeD
Hi Cobalt
Thanks for your advise this has solved the problem.
