1995 e280 w124 starting problems
louisoliver
Birmingham
W124 E280 + LPG
I have a 1995 e280 one of the last of the w124's. it seems to not want to start now and then and will only do so if i slightly depress the accelerator pedal. I have replaced the fuel pump relay and the ovp relay to no effect. What else could be wrong. also does anyone know how I can rig up an led to use the diagnostic socket been told all i need is an led and some wire then count the flases. Cheers
Some info in other thread I will put up a diagram next week
Malcolm
where is the fuel pump relay on your car please
L
louisoliver
Birmingham
W124 E280 + LPG
the fuel pump relay was behind the battery also the ovp relay was back there. That would be great if you could post a wiring diagram. not too bad with a soldering iron just need to know what bits to use and where to put em!
many thanks
louis
topscalcookie
THE WIRRAL
w124 300d
I think im having problems with the relays back there too.I wonder if water gets in there. Is the other unit there the light control unit?
