onlymelloyd
- Oct 12, 2009
- W124 E220
As title, and if it is where do I find the plug?
Thanks in advance.
Thanks in advance.
Thanks in advance.
It is a 14 or 16 pin socket and a blink code reader can be used, its under the bonnet with the cap on it
Thats the one!!
10 i think Malc!!!
The MAF does not affect cold starting and the car will not rev past 4k in N or P I would check the other sensors
whilst I think about it, if i remove the wire of either sensor and then try to start the car in theory it should start and run as if on full choke correct? then when re-connecting the sensor the engine would revert back to being lumpy until warm? so in theory by a process of elimination I should be able to identify which sensor is at fault?
