1996 w124 e220 coupe reliability.
macker64
Ireland
1997 W210 300 Td & 1991 W124 300CE 24V & 2001 W210 320CDI & W210 E200 1992 W124 300ce 24v sportline
Evening folks,
Wishing you all a Merry Christmas and a prosperous New Year.
A good friend has requested I go and look at a very clean 1996 W124 e220 coupe over the holidays and I would like to hear from past and present owners if there is anything in particular I need to look at apart from the obvious.
All comments greatly appreciated.
Regards, :D
syncropaddy
Sunny south east
.... too many cars!
The first thing to do is check from the log book that its an Irish car or an import from the UK. If its an Irish car then there wont be too much rust but if its an import then check around the rear subframe mounts, rear arches, jacking points, around the front suspension mounts, front inner wings, the rear subframe and the front arms. The engine should be good for 200k as should the gearbox ..... the rest is cosmetic!
Is it THIS one?
M
macker64
Ireland
Thanks a million! No thats not the one. Its not advertised apparently!
Regards, :D
d215yq
Valencia, Spain
1987 W124 300D 280k miles
Suspension items and cooling issues were the only things I needed to spend money on on mine. The rest of the cars have IME been bullet proof and incredibly solid with turn key reliability.
They're lovely cars.
grober
Scotland
W204 C200cdi estate
Check the auto transmission engages drive or reverse reasonably quickly. All gear changes up and down should be clean with no flaring or jerking. Check the fluid should be translucent red or yellow. Any clouding/particulates/ dark opacity/ burning smell the box is probably toast.
M
macker64
Ireland
Thanks guys, much appreciated!!
:D
teddycatkin
cheshire cheese country
:D
Right --first thing is the price ---unless you have just aqired a large cash sum and money is no object ??
The w124 with the 220 (m111-slk engine) was not in production long and is a remarkable beast---you need test drive it and take it to its limits to find out just how good it really is ---at the right price it will more than exceed you're expectations ?
M
macker64
Ireland
Ever since I got my w124 300ce 24v coupe my buddy has had his heart set on one of these timeless cars.
He regularly drives mine and has been well and truly bitten by the bug. I drove the 2.2 version and very nearly bought one.
In the end I went for the 300ce and I am very glad I did. Its in a different league performance wise.
The only concern I have is the engine wiring as I believe its of the biodegradable
vintage!!
Regards,
robparker
Taunton
You wont have a problem with engine wiring on the 300-24 model as it has the old injection/ignition system
M
macker64
Ireland
Thanks Rob, I know my 300ce 24v is ok as regards the engine loom, the one I am referring to in the previous post is a 1996 220 coupe which I understand is impacted.
I will check it out when I take it for a test drive.
Regards,
robparker
Taunton
220 loomes are good aswell.. it is occasionally heard of but nowhere near as much as 280/320's, again, aslong as all is running good now I wouldnt worry, the 220 is probbaly the most reliable of the 124 engines overall.
M
macker64
Ireland
Thanks Rob, that's good to know!
Regards, :D
