ukhozi
- Feb 13, 2009
- Location
- Estepona, Spain
- Website
- ukhozi.page.tl
- 1987 2.3-16v, 2001 A170 (W168) Elegance TDi Auto, Eagle SS /VW kit, 1999 Suzuki AN400
I have finally given in and have to sell my beloved 2.3-16v Cosworth to pay the extortionate prices wanted to repair the automatic gearbox on my A170.:cry:
But I can’t as it runs rubbish! I still have the old problem of it being rubbish under 4,000 rpm.
I took it to a Boshe specialist in Malaga thinking they would put all the right instruments on it and come up with the fault but all they did was bypass number one pump and fit a new accumulator and filter which improved it for 3 days and then back to crap.
Putting diesel in it by mistake and then having to drain it out also improved it for three days, so something got lubed and improved its function.
I was wondering if it could be that the fuel pressure bypass unit between number one and two inlets could be faulty and allowing too much pressure in the distributor and thereby to the injectors, this would explain why she runs like a banshee from 4,500 up to 7,200 rpm and smooth as silk at a tick over of 2,000 but not low down and the exhaust and plugs are sooty.
Work so far;
The compression printout I was shown was 5.4 on all four but he did it with the throttle closed, as all four were the same this ruled out individual cylinder problems, it doesn’t use any oil anyway.
A check on the valve clearances showed clearances were all within tolerance and cam timing hadn’t jumped on the chain, (not that I can see how it could do it but it has been suggested). Cam shaft lobes are in perfect condition.
Plug leads are new silicon ones with new metal shrouded caps. New plugs, OK
I changed the complete air flap and distributor assembly with a known good one and it made no difference.
New air filter, no change.
Repaired and taped air pipes from rocker cover to air valve, no change.
Air valve opening and closing as it should on 12v command from relay.
Exhaust O.K.
Voltage protection relay OK.
Fuel relay changed and no difference.
All wiring check on temp sensors etc and any cracked, iffy areas taped up.
Comments please
Work so far;
Exhaust O.K.
Comments please
