2000 c240 2.6 cutting out
Model31man
London
C240 2.6 2000 (x)
Hi all, recently bought a 2000 c240 petrol 2.6 off a friend who said it was running perfect. He had recently replaced the crank sensor with a Bosch one as the old one was faulty. Since owning the car a week I've discovered that you cannot rev the vehicle above 3000rpm. As soon as the revs get to 3000 it cuts straight out. I put the car on a cheap obd reader which came up with P0335 crank sensor circuit a. I would of thought if it was a crank sensor it wouldn't run at all but it runs perfect up to 3000rpm????? Please help!!!!!!!
rpe2
Silchester
E53 Estate, 124 Cabriolet, 129 SL
I think that you are going to need to have the codes read by a better code reader (Star or such like).
I'd guess at an air mass sensor, but it is just that - a guess.
Welcome to the forum.
Steve@Avantgarde
Bristol/Somerset
C43 AMG PP/NE, SLR McLaren Roadster, SL55 & C32AMG
The last time I had this, the car had gone to another garage for a crank sensor which had siezed in its hole. They had drilled out and damaged the teeth on the flywheel in the process. The car kept stalling above 3000 rpm and they couldnt work out why. It came to me when I discovered the fault then I explained that missing teeth on a flywheel isnt good as the CPS needs to see all of the teeth to be able to count the revolutions of the engine. I fitted a new flywheel and all was good again.
star
Reading
Smart + others :)
Are you trying to rev the engine in neutral or park? There is a rev limiter in both.
Alex Crow
Super Suffolk
My thinking with Steve here, bent reluctor tabs will do this, could be an easy fix.
M
Model31man
London
C240 2.6 2000 (x)
Hi there thanks for your replys, it cuts out when ever your driving or stationery in neutral. New crank sensor was fitted about 4 months ago, which old one was seized solid in hole and had to be drilled out - maybe exciter ring damaged - but why would it start and run fine up to 3k rpm?? Help!!! Thanks!!
M
Model31man
London
C240 2.6 2000 (x)
How would you straighten bent reluctor tabs??? Thanks Scott
Steve@Avantgarde
Bristol/Somerset
I cant prove it but I would say the pulse rate at the lower rpms would not be enough to cut it out but the higher rpms it cannot cope with the amount of signals missing
M
Model31man
London
C240 2.6 2000 (x)
Ok thanks for your reply's.. I'm looking at selling it now so any offers please contact me on 07949860427. It's on an 2000 X plate, currently on 107k with full merc history upto 98k. Four new wings 5 years ago, excellent condition inside and out. Scott
