2001 clk will not start any ideas?
turbopete
Spennymoor
I see that the starter on a 203 is driven from the front SAM,,these are always failing, the fault could well be here
To take the starter off if it an exhaust off job
its a clk Malcolm. going on my newly printed chart (lol! taking things serious now!) 2001 will be the last of the 208's or maybe a 209. 2001 seems to be the crossover pont!
A
allforfun
  • #22
i am confused what are you talking about ? do you think its a starter fault or could it be something else ? battery has planty of power key turns ok and makes noise i can move in and out of gears but all i get when trying to turnover is one click ?
turbopete
Spennymoor
Malcolm was saying that on a 203 (c class) the starter is controlled by the rear sam unit (a kind of collection and distribution module for the electrics in more simple terms) and these are prone to failure which could give similar symptoms. i was pointing out that yours is a clk not a c class, but it may still apply, im not sure. depends whether its a 208 or a 209 chassis id guess! these are the second 3 digits of the vin (first 3 numbers after the initial 3 letters)
The starter does come out from the bottom
turbopete
Spennymoor
i think the heat and all that garden centre excitement in the SL has been too much for you Malcolm! maybe you shouldve treat yourself to an ice cream during the day to cool your brain down to a more optimal operating temperature! Besides, we all have them! i had 1 the other day!
The starter is driven from the K40/4k2 starter relay
I just hate giving up Pete, these thing used to be so simple
Cole@MBS
www.mbssouthampton.co.uk
On a 203 the starter is controlled by the front SAM, not the rear as has been said. on a CLK 208, the starter output is from the k40 relay, best bet is to shoot 12 volt down the purple wire from the k40, been following this thread, the car has a dead battery!
Cole@MBS
Just thought of the other common fault with them, Where the main power feed for the starter comes via the n/s floor, they rust, try cleaning that post up. thinking about it, thats prob it!!
What makes it hard is that we have no feedback as to what voltage is present anywhere
turbopete
Spennymoor
tell me about it! when i first started serving my time in a retail ford dealer's my main work was mk 1/2 fiesta's mk 3/4 escorts and mk1/2 sierras. cupled with an odd capri, cortina, mk2/3 granada and you could solve more or less everything with a multimeter, A big hammer, a screwdriver, sidecutters and insulation tape!!!
SQ_W211
W219 CLS55 AMG
I take it the issue went away or he gave up DIYing on tackling it himself.
A
allforfun
  • #33
no the issue did not go away i could not borrow a ramp until today so had to tow the car away to the ramp where i found the fault within a minute the power cable from passenger side football had corododed and broken apart so it was just a matter of replacing the cable end and job done thanks for all your help especially the person that mentioned the passenger footwell power supply many thanks
Thanks for posting a good result
A
allforfun
  • #35
no problem glad someone could point me in the right direction and glad i did not have to remove the starter motor looks a pig how do you undo the top bolt ?
You need a very long extension with a good universal joint
Tel: 020 8863 9233
